Dakzuki
Sep 16, 2015Explorer II
DiploStrat wrote:
A volt meter doesn't really tell you anything you need to know in an RV. When you are on charge, it will show the charger voltage (grossly) and when you are not it will show an artificially lower voltage depending on your loads.
You want an hour counter, or, perhaps, a SmartGauge: SmartGauge
It tells one quite a lot as the battery "percent charge" table supplied with my Lifeline AGMs is specified in terms of voltage. If one knows when to check and how to interpret the numbers it works just fine.
I will no doubt get more exotic in the future (once I get solar on) but the voltmeter works quite well.
