OLYLEN
Sep 17, 2015Explorer
12.2 volts is 60% charge. Is your reading under load? If so you have more than the 12.2 left, quite a bit more. True battery condition is at rest a time between charge and use. Running the refer on just 12 volt? Is it a three way refer Gas, 120 volt or 12 volt? If so run it on LP, it will still need 12 volts for the brains but that is lo draw. Charge at or before bed time until quiet hours.
LEN
LEN
