sgordon_lazydaz
Sep 06, 2021Explorer
Water pump, water heater both have been switched off. I installed an inverter to the house battery but it's off when I'm not using it. Rear camera wired directly to the house so could be actively pulling power? But then again I had installed for months with no battery issues. Will obsessively search again for any compartment lights. Wouldn't a fuse appear blown in house if there was a short? Ive checked the house fuse box and all fuses are good. How about fuses related to car battery? Any idea where those would be located?
By bad ground do you mean the actual connection to the ground on the battery? Sorry I have very basic electrical knowledge and very little knowledge of cars. This is proving to be a good excuse to educate myself more on both.
The isolator seems to be connected to both batteries but unsure exactly how it's wired.
I'll check for a built in CO detector, I installed a smoke/co detector in the ceiling but it runs on batteries/not wired to house.
Any other tips are highly appreciated! So glad I found this community.
Thanks!!
Thanks!!
