Matt_Colie
Sep 06, 2021Explorer II
SGordon,
Until you get it sorted out, get in the habit of pulling the negative cable of both the chassis and house batteries when you shut down. It will be a pain I know, but it is easier that dealing with dead batteries all the time.
Now, as soon as you can, get wire, two alligator clips and a small 12V bulb. Solder the wires on the bulb and the clips as well. Then put it between the disconnected battery cable and the battery. If/when it lights, you have a problem (I think you know that), so, keep pulling fused and disconnecting things until the light goes out.
You bought this coach used. There is a real good chance that someone that doesn't know better hooked things directly to the one or the other of the batteries. This happens all the time.
Matt
Matt
