capacitor
Sep 06, 2021Explorer
The isolator may be bad allowing the coach bat to drain the chassis bat but this doesn’t explain where the drain is. Remove wires from the isolator and charge coach bat. Once completed check voltage and check again in a few hours. You need to find where the drain is, coach or chassis.
