Gary45
Sep 06, 2021Explorer
Just remove the (charging) wire from the house battery, you should be able to charge the vehicle battery and start it. You can hook your charger up to vehicle ground and the disconnected house battery charging wire to charge house battery. Then one of the batteries will discharge quickly pointing you to the problem.
38,782 PostsLatest Activity: Sep 20, 2026
