bobndot
Sep 06, 2021Explorer III
Still a bit confused on how to check where the source of drain is coming from as this is all new to me but will study over everyones notes and try and locate the power drain.
You can use an inexpensive multi-meter . Hook up meter using the amp setting. Disconnect the negative cable off battery of choice to test things on the coach or chassis side.
Hope this vid helps and explains the ‘how to use’ a mm to test.
https://youtu.be/KF1gijj03_0
38,782 PostsLatest Activity: Sep 21, 2026
