2_many_2
Sep 06, 2021Explorer III
Some older RV refrigerators have this:
"The climate control switch (sometimes called a humidity switch).is used to control frost that may collect during very high humidity situations. The RV refrigerator climate control Switch controls a 12-volt heat tape behind the metal frame around the refrigerator and freezer doors."
This switch is often a small toggle switch semi hidden on the frame of the door on the fridge. Even when the fridge is off, if this switch is left in the "On" position, it continues to draw power.
This was a common problem when the switch was overlooked causing dead batteries for seemingly no reason.
38,782 PostsLatest Activity: Sep 21, 2026
