klutchdust
Mar 22, 2021Explorer II
When my coach was on ground power the chassis battery would be dead in 2 weeks from all the parasitic drains. I plugged a battery monitor into the 120 wall outlet that were hot from the ground power and plugged the other end into the accessory port on the dashboard. Problem solved.
I like Charles recommendation when using your slides. Mine required that .
