coolmom42's avatar
coolmom42
Explorer II
Mar 22, 2021
Battery & electrical questions
I have a 2014 Coachmen 21QB on a Chevy 4500 chassis, with an Onan 4KW generator.
*Does the generator have its own starting battery? If so, how is this battery charged? Or does the generator crank off the chassis battery? (I'm assuming it doesn't crank off the house battery, as that would kind of defeat the point of having a generator.)
*Does the generator charge the chassis battery?
*Does the chassis alternator charge the house battery? If so, how well?
*Does the battery isolator switch completely isolate the house battery and chassis battery from each other?
*Does the converter charge the chassis battery when the RV is plugged into shore power?
*On the side of the engine compartment, there is a 200 amp fuse. What is this for?
    The genny rarely has its own starting battery. Stand alone generators such as the Champion 3400 do. But not the Onan.
    Sometimes. Some designs are powered from the chassis battery for starting, others may use the house batteries. If it is does not, it is easy to add a Trik-L-Start.
    Yes, but not very well. A great upgrade is a dc to DC charger.
    Usually.
    Not usually. There are several many solutions to this, such as the Trik-L-Start.
    Here are the three words men don't like to say.
    I don't know
  • Matt_Colie wrote:
    Coolmom,
    Mike had good answers, except for one. That one is easily checked.
    I have seen very few (like 2) coaches without modification, that charged the chassis battery from shore power.
    This can be added if you find you need it.
    Matt
    You're right. My bad, on charging chassis battery.
    As I said, "if I understand your questions".
    Missed one. :B
  • Coolmom,
    Matt
    Most generators do use the coach batteries for their starting power, at least in my limited experience. Disable your coach batteries, and try to start the generator, as a test.
    No, usually.
    Yes, usually. Depends on the alternator amperage, ambient temperature, and size of the bettery bank to be charged. In general, I've always found it decent, if you drive enough between coach battery usage.
    It's usually a diode (one way only) switch that allows simmultanoeus charging of all batteries, but that won't allow the coach battery system to borrow power from the chassis battery, so you (in theory) won't kill your starting battery by drawing power fromm it to run the coach 12V DC loads.
    Usually, yes.
    EDIT: As per Matt, usually no. My bad.
    No idea. Sorry.
    This is anecdotal info based on motorhomes I've owned, and my experience and understanding of their power systems, and your questions.
  • “On the side of the engine compartment, there is a 200 amp fuse. What is this for?”
    Less than 200 amps! lol
