time2roll
Aug 27, 2013Nomad
You have 450 Ah rated capacity so 500 is close enough. Definately move it to LA 13.4 volts. Turn off any automatic equalization.
Is that temperature compensated? Charging/floating on a hot day (100+) will have the batteries gassing more.
Looks like fluid might be dripping off that right hand cable. (first pic) I would be tempted to tie that cable up so it does not collect moisture and direct it down on the pan. Or put a plasic pan under it after you clean up the metal.
BTW my batteries are are in a trailer so not necessarily a fair comparison. Although I did wipe them off once. Mine float at 13.3v
