WEll just for information to all those in the future who this might help. Here's what we found and done. The last mechanic put the wire to the slide {slide wire} from the coach battery to the motor battery which is wrong, the slide needs to be able to run from the 12 volt coach battery system.
#2 There was a wire bad running from the slide so that was replaced.
#3 the brake switch for the emergency brake was faulty not connecting well and had to be replaced, this had to be ordered, so I'm still waiting on the bill ,but expect everything to be in working order soon .
Thanks for all the help you guys are great.
Randall
