Mandalay Parr wrote:
Seems redundit to drag around another generator and charger. Your 2016 Lance probably has a decent converter and generator. I'm no expert but a real fast charge may not be the best for battery life.
This is my initial gut feeling too. Especially since there already is some solar present.
More details are needed....like what make and model converter/charger do you have ? Hopefully it has a relatively fast bulk charge mode and your onboard gen will use less fuel when lightly loaded.
I have found that I need/want AC power enough hours a day that it also keeps the batteries near to topped up as a side benefit.
If your TV/satellite equipment is AC powered I'm pretty sure that keeping the batteries charged will not be a problem.
