ksg5000 wrote:
Make sure you battery disconnect switch hasn't been accidentally toggled - that takes the batteries off line. Also - somewhere near your batteries will be a fuse/circuit breaker(often an auto reset breaker) - make sure that's OK.
Rigs are wired differently - many rigs have there generator wired to coach batteries and if they are offline/low then you won't be able to start the generator.
We will search all those out, fingers crossed that could be it. Not sure if this is the same as on board generator, but if we can get everything working but the generator, would our portable gen do the same job charging batteries with Motorhome pluged into it. That may be something we should know, but hey we don't lol.
Thanks so much, just being pointed in a direction is helpful. A place to start. Tonight after DH is home from work and over the weekend, many many projects and problems to solve or at least take a crack at.
