LOG
Mar 30, 2020Explorer
pianotuna wrote:
Log,
Voltage may be the least accurate method to check state of charge. I suggest verifying the charge level a few times using a temperature compensated hydrometer. You may be surprised at of "real" state of charge where the battery charger goes into float mode.
My battery tester, a state of the art micro-load electronic tester, shows voltage, state of charge, amp hours, cca, marine cca, percent of amp hours, etc.
It is the same one use by auto/rv shops around the US.
I recommend that you research micro-load battery testers.
