hoss-n-dawgs
Jul 31, 2019Explorer
Battery Charging Problems
The alternator from the MH will charge the house batteries. However, when connected to shore power the inverter will reads "Absorb charging" 13.5 volts, while the battery disconnect reads 11.5 volts. The inverter will go to maintenance charge even when testing at the batteries remains at 11.5 volts. The generator will not charge the batteries as well. If I'm running the generator for an extended period of time it will drain the chassis batteries. Help!
