What Brand/model of converter/charger do you have (or inverter/charger).
The 'charger' output while on shore power or generator is low.....
Connect to shore power for a few hours
B1 12.6 B2 12.6
Disconnect shore power, connect and run generator
B1 12.7 B2 12.67
You are seeing higher voltage when running engine.....but the charge line is small so charging of batteries would take hours.
Need to test 'charger' output with battery cables disconnected.
With 110V AC power in.....charger output should be 13.6V DC. Anything less 'charger' is not functioning properly.
Also check that you didn't connect battery cables backwards and the 'reverse polarity' fuses on converter/charger are blown.
If they are blown the charger output can't get to batteries.
