dougrainer
Feb 04, 2014Nomad
TexasH wrote:ROYBUCK wrote:
I would like to shut the charger down how can I do that I am plugged into shore power. I have the Xantaex freedom 458 Inverter/charger with the energy management system. Thanks Roy
My converter has a 120v plug near it and it is just plugged in there. If yours is powered that way, just unplug it. But be aware that will shut down all the 12v systems. If you just want to shut down the charger, disconnect the battery wire at the converter. Then the 12v systems will still work. your refrigerator, heater, and many lights may be powered by 12v controls.
He does not have a Converter. He has an Inverter/Charger. Different animal. ROYBUCK, please respond to my question. You state you are removing the batteries or disconnecting them and you want to shut the charger section down because you will be on Shore Power. WHY??? With no Batteries or the Charger inactive, your RV and systems will be useless regardless of being on shore power. The ONLY thing you may run is your TV system and the Microwave and IF you have an RV refer that will not operate either. Your Roof Air units will not operate either. You MUST have 12 volt power to operate a RV. Doug
38,770 PostsLatest Activity: Apr 12, 2026
