ROYBUCK's avatar
ROYBUCK
Battery Compartment leak ( Up Date)
Found out it was the battery, thanks to some of your suggestions. I went and purchased a Hydrometer, I had 2 cells bad in one of the batteries. My question it seems like the battery just leaks when it goes trough the charging cycle. I have checked on U2200 Interstate at $89.95 each, will wait until spring not going any where until then, I would like to shut the charger down how can I do that I am plugged into shore power. I have the Xantaex freedom 458 Inverter/charger with the energy management system. Thanks Roy
  • The U2200 I have is going on 7 years, how much longer will the AGM last. Roy
  • If Bad batteries and you want to shut the Inverter/Charger down, WHY continue to be plugged into Shore Power????????????????????????. The Remote panel depending on your year model of Inverter and the remote, you have a button that turns the charger OFF. Doug
