JD38ExplorerMar 11, 2017Battery Control Center solenoid dropout voltage2001 Fourwinds, Gas V-10, Intellitec BCC. Ever since installing new batteries I can not get the chassis solenoid to latch without starting the engine. But the coach one does latch without the engine ...Show More
enblethenNomadMar 11, 2017Wired something wrong or bad connection. Should pull in and latch around 11.0 volts
Related ContentSway ControlBattery Disconnect Solenoid FuseBattery Disconnect SolenoidBattery disconnect solenoidAG battery switchover
