- J-RoosterExplorerI've never done it!
- TechWriterExplorer
rjxj wrote:
How much voltage variation do you see,
Don't know what you mean.rjxj wrote:
does it tend to not hold a charge as well?
Possibly.rjxj wrote:
many volts does it go to for agm's?
15.5V - azrvingExplorer
TechWriter wrote:
After 2 years of use, I'll be equalizing my Lifeline AGMs soon. With my Magnum ME-ARC remote control, equalizing has to be done manually.
How much voltage variation do you see, does it tend to not hold a charge as well? How many volts does it go to for agm's? I've never used agm's - TechWriterExplorerAfter 2 years of use, I'll be equalizing my Lifeline AGMs soon. With my Magnum ME-ARC remote control, equalizing has to be done manually.
- Two_JayhawksExplorerI installed new house batts in 2006 and figured to equalize charge "some time down the road". I never got around to it and I am pleased to say my 8 yr old batts are still healthy. Doubt I will. I think it's necessary with large industrial batteries but not so much with these little batts.
- chuckftboyExplorer
rjxj wrote:
chuckftboy wrote:
I have a Progressive Dynamics PD9270 with Charge Wizzard. Suposed to have automatic equalization and it does just fine. I have (2) T105's that are now 7 years old and still have good specific gravity and voltage readings
Have you ever checked the voltage at equalization? Does yours automaticaly go into boost at 14.4 or do you have to manually set to boost?
Actually I did check it once when I first got the coach. Yes it did go to 14.4 on a Fluke meter and yes it is totally automatic. - camper19709ExplorerNope. Never have and have no plans to do it.
- azrvingExplorerThis is from Mexicowanderer
BATTERY EQUALIZATION
Remember those wheeled gas station battery chargers? The customer brought in a battery to be charged, the attendant connected the charger cables, set the machine on “High” Setting, twisted the on-off timer to as far as it would go (usually an hour) and then told the customer to “Come back after an hour”. The charger usually had an ammeter, but just as usually it was ignored. “Plug and Play The Early Days”.
Today's converters and chargers have pre-determined “charging limits” but those limits are programmed into a control board integrated circuit that ignores the battery just as badly as the gas station attendent ignored the wheeled battery charger's ammeter. Say hello to “Plug and Play 2014”. The integrated circuit programming is based on a premise of “Well, take your best guess”.
It does not work. The only advantage today's “Smart Chargers” have over a gas station charger is that they are less likely to overcharge the battery. Rather, because manufacturers are less likely to be sued over an undercharged battery that failed prematurely, 99% of smart battery chargers tend to undercharge their batteries. This is supposed to be an improvement.
RV battery usage (and life-span) can be likened to the difference between a Manhattan taxi cab versus the proverbial “Little Old Lady's Sedan” that only got driven to church on Sundays. The taxi sees constant “heavy-duty” service, requires more often and more meticulous servicing, and even with the best of care does not stand a whim of a chance to last as many years as the Little Old Lady's sedan.
Such is the difference between an RV battery that goes boondocking frequently and for prolonged periods, versus a battery that endures merely periodic Infrequent weekend usage, or spends a majority of it's time connected to a power pedestal.
What would you think of a Little Old Lady that marches up to the cab driver, puts her hands on her hips and declares “Well! My car has served me perfectly for nine years! It's just like new. You're doing something wrong if “your car” lasts only five years, and leaks oil. Your car is constantly in the garage getting fixed!”
The point of argument is absurd. An argument of “my battery lasted longer than your battery, and did not require the attention you gave yours” is subject to the same rules.
ELECTRICITY IS A BY-PRODUCT
Most consumers think of a battery as “electricity”. This is an error. A battery is chemical laboratory and electricity is a mere by-product.
MANAGING A BATTERY PROPERLY IS A HASSLE
Seventy years ago, about ninety nine percent of what is know about battery management was learned and proper battery management practices adopted by the US Navy. The more than one-hundred fleet submarines and thousands upon thousands of battery cells demanded a steep learning curve or people perished. Submarines simply did not return to the US and get frequent battery replacements because battery cell replacement was a true hassle. You are aware of the requirement to never mix a new battery with an old battery. How would you like to deal with this issue when it involves dozens and dozens of batteries?
There are shortcuts, and battery management “tricks” that reduce the time and effort spent maintaining a battery. The rewards are increased battery capacity throughout its lifespan, and an impressive increase in lifespan.
THE DESPISED HYDROMETER
People who rant and rave about hassles involved with hydrometer use, almost without fail do not know how to use a hydrometer with regard to their battery.
POINT!
Every battery with more than one cell has “The Weakest Cell” This cell is the first to deplete the acid density and the last to recharge (restore specific gravity – return to 1.275 full charge). This is the “whipping boy” for hydrometer testing. Once a battery has been tested with the hydrometer, and the weakest cell detected and its position noted, this is the cell you return-to first with the hydrometer. If this cell is “normal” fully charged or depleted, the remaining cells will read a higher specific gravity in that battery. Find that lowest reading cell and exploit it. Equalization is performed when standard charging does not drive the sulfate off of the battery plates and back into solution. When you assume your battery is fully charged, but the whipping boy says via the hydrometer “But not me!” you have a problem. You need to fix it. Your recharging protocol needs to be adjusted. Whatever it takes. One constantly weaker cell amongst two or seventeen other cells that tend to always read similar to each other, the majority (but always higher) is a sign of a bad cell – a bad battery. You cannot whip the entire work-force to enforce correct conduct by one employee. Too bad the bad boy is part of a team, a battery, thus the “team”, the battery, is doomed. Everything is progressive – a cell that is a “little” wayward can be tolerated. A real delinquent however can affect the lifespan of all other cells and must be culled from the herd.
Thus, checking a battery usually involves only one cell.
Do yourself a favor and dig through your unneeded clothing and find -anything- that is made of wool. Wool is immune to battery acid. I got a large wool sweater from a Salvation Army store for a dollar and cut off the arms and made a great “tarp” from the remains.
EQUALIZATION
Equalization is a term. It is an incredibly specific protocol that involves a precise formula and brooks no deviation from the formula. I'll say it in somewhat ruder terms, either you use the formula as specified or you are playing with the battery, not equalizing it. Equalization, the formula was created many decades ago by professionals and the formula was used on US Fleet submarines, religiously.
Like many other protocols in today's world, the term 'Equalization” is misused, even abused. Marketing hype, and BS Artists have turned the term into a buzzword. A joke. Too bad the joke is on the consumer. “Press This Button To Equalize” is now meaningless. “Press This Button When The Charger Integrated Control Circuit Fails To Properly Recharge Your Battery” is the correct way to label such a system. Notice above, the word “When” is not the word “If”.
A group 24 battery needs a -constant- FOUR AMPERES of current for equalization.
Group 27, 5-7 amperes.
Golf Car, 11 amperes
Group 29, 6-8 amperes
Scrubber battery, (1275) 7-9 amperes
L-16, 18-20 amperes
This constant amperage should not vary too much out of line. As an example, starting with a fully charged Golf Car battery, a starting surge above 15-amperes should not be tolerated. Back off the charge rate. The formula is officially 5% but personally I tolerate four to six percent of total ampere hour capacity of the battery. A standard transformer charger in conjunction with a VARIAC, can yield an exact 5% ampere charge rate and periodic tweaking of the dial on the VARIAC can control amperage to within the percentage limits of the equalization. My personal, monster 2-volt cells demand one hundred twenty amperes constant, to equalize. This was a challenge.
Start out with a battery as fully charged as you can get it.
Apply amperage as specified in the list, above. Amperage, not voltage is key.
Maintain that level of amperage until one of two things occur.
The lowest cell reverts to original density
8.0 volts is reached on a 3 cell battery or 16.0 volts arrives on a 6 cell battery.
Just for your information, every -tenth- of a volt less than 2.666 volts per cell increases the time needed to remove plate sulfation by a factor of 1.3 (call it by percentage. 130%).
Use common sense when checking the “Whipping Boy” cell with the hydrometer. If the cell is sluggish to respond, check adjacent cells. If they have reverted to 1.275 density but the whipping boy refuses, then the battery is bad. One low cell when other cells seem to have equal but higher density, is a cause for suspicion by itself. I like to think of it as “If a cell cannot walk and chew gum at the same time – to the recycler it goes”.
BATTERIES SHOULD NOT NEED TO BE EQUALIZED OFTEN!
Top Charging (My own personal terminology), should be employed in regular battery service. This means to charge an otherwise “full” 12-volt battery from it's regular float voltage to 15.0 volts at the same 5% rate as listed above, but the amperage control need not be as strict or precise. 15.0 volts is a heck of a lot easier and faster to reach than 16.0 volts. I top charge my batteries once a week...
And have reduced the need for formal equalization by 800% !
Eight times as long between equalizations. Top charging is magic. It also stirs electrolyte, and in practice is not as “hard” on battery plates as is a full equalization.
MANY BATTERY BRANDS ARE INFERIOR
Let's face it. Too many brands of batteries will develop inequality in acid density between cells – at the drop of a hat, even when nearly brand new. They rapidly get worse. This can confound a consumer to no end. Choose your brand of battery wisely. Hundreds of positive reviews are the best recommendation in my opinion.
AND DO NOT FALL FOR UNINFORMED OPINIONS
An individual can purchase an inferior battery, or mistreat a good battery and yet believe with utter conviction that the battery is in an excellent state of condition. How is this possible? It is possible by not utilizing the battery's capacity to the point where weakness or inadequacy does not makes it's ugly appearance. The battery is not monitored, not checked, and under-used. Because it does not mis-perform, for the owner it is a wonderful device. The owner may be an individual with “strong convictions”. They'll spend hours, days, and months, trying to convince others that battery maintenance is a snap, their battery has lasted ten years (or even longer) with plug and play charging, and they did nothing more than add a little distilled water now and then. Why did they not notice the battery was weak or got weaker? They do not use it heavily. The battery always lives and relaxes in deep-clover. A lawnmower battery would work for the individual. But strong opinion can have a powerful voice. One of the toughest tasks around is to show a strong-opinionated individual that his belief is without foundation. Misinformation pressed upon willing ears, can do a lot of damage.
It is up to individual battery owners to separate fact from fiction. But I'll share a secret with you:
“I listen to someone describe symptoms of a battery problem. As I listen and form opinions, I may arrive at a tentative “conclusion” as to what is going on. Then the battery owner could say “I took a hydrometer reading and this is what I found”. It is not unlikely my tentative conclusion could be wrong – the appearance of hard data could make my conclusion catch fire and go up in smoke. My conclusion after all, has its basis in guesswork”.
Don't be misled by guesswork. - fischerExplorerTrojan say not to equalize unless the specific gravity varies after charging. And to remove the load before equalizing.
- azrvingExplorer
38,774 PostsLatest Activity: Apr 26, 2026
