If you set the charger on the MH to equalization running the generator will it charge both chassis & house batteries with a equalization charge or just the house batteries? Thanks
You got to be careful when you equalize your batteries. Manual recommends to be sure that power is turned off to sensitive boards which could be damaged by the high charge rate. I turn off everything inside the coach while equalizing the house batteries. I never have equalized the chassis batteries.
