et2
Nov 30, 2014Explorer
Battery Equalization
If you set the charger on the MH to equalization running the generator will it charge both chassis & house batteries with a equalization charge or just the house batteries? Thanks
wolfe10 wrote:
If your charger (or inverter/charger) charges both battery banks when in "normal" mode (bulk, absorption and float) it will certainly charge them in equalization mode.
So, you will need to verify that it does charge both banks.
With digital voltmeter:
Engine off, shore power off. Check chassis and house batteries voltage at the batteries. Fully charged is 12.7 VDC. Surface charge may have it above that, though turning on headlights with all charging devices off for a few minutes will dissipate the surface charge on the chassis batteries.
Plug in/start generator. If the chassis battery voltage goes from under 13 to 13.7-14.2, then yes the chassis batteries are being charged and equalization will also equalize them.
