I was hoping to confirm the correct way to connect my coach battery bank. I think I've got it wired incorrectly since performing some battery maintenance. The batteries appear to be charging (I've got...
Normally the only heavy draw appliance on the inverter is the MW. The refer and HW should not be on the inverter. Perhaps someone rewired your MH? Does the HW work on propane?
Good time to check the charging. With discharged batteries you should see 14.4V+ bulk charge tapering to 13.4V+ float.
