mfox20ExplorerMay 02, 2016Battery IssuesBattery History: I have 4 (6V)Interstate batteries that are 6 years old and maintained with Xantrex GS Series Inverter Charger and ProFill watering setup on my 2000 HR Endeavor gasser. I typically sta...Show More
pianotunaNomad IIIMay 02, 2016Hi,If you never camp off the grid get a single used 12 volt surplus acid AGM and put it in place.Unless there is some reason, I'd unplugged between trips and plug in 48 hours before leaving. I'd use a battery disconnect switch in between times.
Related ContentTowing lights issueAG battery switchoverBattery Issue?Battery issuesElectrical/Battery issue.
