donn0128
Nov 27, 2017Explorer II
Salesman, storage, or what ever you want to call it. The switch with a big red lever. Is it on or off? If its on, then next step is to check voltage from the converter. With the battery disconnected and 120VAC to the coach check the voltage at the battery leads. It should read at least 13.5VDC. If not your converter DC output is dead. Possibly a bad converter or simply a blown fuse.
