simonov
Aug 19, 2018Explorer
Battery location: 1993 Jamboree Searcher
You're not going to believe this, but I am pulling my hair out and am really confused.
I have a 1993 Jamboree Searcher 26' on a Ford E350 chassis. It has been sitting idle for almost two years, and I would only start it to move it or to take it down to the emissions testing station.
This year I tried starting it again and the battery seemed to be dead. I put a trickle charger on what I assumed was the chassis battery and fully charged it and the car wouldn't start. Then I charged the other battery, which I thought was the house battery, and once it was charged the car would start. But this battery wouldn't hold a charge and I was obliged to put the charger on it again the next time I needed to move the rig (a couple months ago).
Today I decided to replace both batteries. There is a battery on the passenger side, which I assumed was the chassis battery, and which is charged to about 12½ volts. The battery on the driver's side won't hold a charge, and currently shows about five volts. The starter won't even tick with the auxiliary switch on.
Now, my assumptions:
o Passenger side battery, only a couple wires coming off it, 12½ volts, can't read any of the labels due to dirt and other ****. I thought this was my chassis battery.
o Driver's side battery: lots of wires coming off it, including a big knife switch, and it's an ACDelco car and truck battery (I'm sure if it was a deep cycle battery the label would indicate this). I assumed this was my house battery.
Both batteries were installed by the previous owner.
Questions:
o If my assumptions are correct, why wouldn't the rig start when the chassis battery was fully charged, but only after the house battery was charged?
o Can you really use an ordinary truck battery for a house battery?
o Are my assumptions incorrect? Could the passenger side battery be the house battery and the driver's side battery be the chassis battery?
o If I am buying new batteries for this rig, what do I want to get and where do I put them?
The manual, as many of you already know, is so general as to be almost useless.
Questions:
