chastho wrote:
I think you may be over charging the batteries, are you sure your 4 Trojans are 600 ah? Mine are 220 each which is 440 ah. Have you checked the water level in the batteries?
4, 220's are ? my battery pack is 2 six volt 220 amp batteries in series for 12 volts, in parallel with two more, for a total of 4 batteries delivering 12 volts to the inverter, with an amp hour capacity of 220 X 4 = 880 total AMP capacity.
Yes on the water levels.
Charging at 15.5 volts will cause the batteries to gas profusely, and they did, but they did not loose any water.
