ECones
Sep 06, 2015Explorer
Battery problem
Our battery in the RV went down this weekend and wouldn't stay up while running down the road. I checked it once back home, and with the switch in "Store", the battery puts out about 8.5 volts whet...
tenbear wrote:
12.5 to 13 volts is lower than I would expect to see when being charged by the alternator or by the converter. I would expect the alternator to put out 14+ volts. The converter, depending on the converter, could be anywhere between 13.2 and 14.4 volts.
What is the voltage on the chassis battery when the RV is unplugged and the engine is running?
If the charging voltage drops below 13.2 volts for a period of 4 seconds due to low idle speed and or excessive load, the isolator will disconnect the auxiliary batteries until the voltage returns to a level of 13.2 volts for about 10 seconds.
