topbuddy10 wrote:
Yes I do have an invertor/convertor. I will check it out. Thanks
No such thing. You have either below. Odds are it is a Converter only
1.Inverter/CHARGER
2.CONVERTER
As another poster stated, a REQUIRED tool for an RV'er is a simple cheap Multitester. That way you can check for 12 volts and 120 volts. You need to verify the batteries have 12 volts. Usually, when you have a Winne Battery disconnect system which used Intellitec solenoids. either the 5 amp ATC fuse on the solenoid was blown or the Solenoid itself is bad. Check the 2- 5 amp fuses on the disconnect solenoid. Doug
