LaTriker's avatar
LaTriker
Battery Problems
I drove my MH today after it had been parked for three weeks plugged into 20 amp power. I drove 15 minutes then stopped for lunch. I checked the voltage before leaving the MH. The voltage display showed 12.5 volts. The only things on at the time were the residential fridge, the inverter and the battery charger. I came back to the MH in one hour and voltage showed 10.7 volts. The inverter had cut off. I cranked the generator and the charger started bulk charging. After about one minute, it switched to absorb charging. Does that sound like an inverter problem or are the batteries shot? I have four six volt batteries that are three years old.
  • I think I could answer most of oldman's questions and I don't think the answers mean much. An important question however is how much water is in your batteries. If they are low it could mean that they are being overcharged and boiling off the electrolyte. I think you may have one or more bad batteries and would have them load tested as a group and individually. If the converter has a pendant, it would show the bulk charge but to drop from 12.5 to 10.7 volts in just one hour is weird and sounds a lot like a bad cell in one of the batteries. Here is the sketchy part, with the batteries being only 36 months old and normally they are rated for 72 months, do you need to replace all four? We used to replace bad cells in our 512 cell battery but only once did we replace all the cells. Then again we had to cut holes in the hull to replace them all.
    Making sure all the connections are good after the individual load test is a good idea, if they need water add some before driving over to have them tested. You need to do all those normal things we all forget to do or put off on occasion sometime during this trouble shooting procedure.
    Sorry about the curt reply to you but he sounded like he knew a lot about what he wrote.
  • Something is screwy.
    What do you mean the 'battery charger' was on? Do you have an inverter/charger? Why did the inverter cut off.. low voltage? What sort of meter tells you the generator went to absorb charging? Is there enough water in your batteries?
    Even at 3 years old, if the batteries aren't maintained or are over-charged they will be shot. That's my first suspect.
