Edited to add: The battery is fine, the Charge Wizard did it's job and the battery was fully charged and perfect. I on the other hand am a dork. I forgot that I had hit the "Battery Disconnect" swit...
Something has happened to cause your AGM batteries to go bad so fast. Could be inadequate charging or improper charging.
The battery techy types can weigh in here. I am given to understand that a standard RV converter can ruin either an AGM or a wet cell under the right circumstance.
