Sam_Spade
Sep 08, 2016Explorer
J-Rooster wrote:
MountainAir05, Thanks for your quick response the DW told me I should shut them off even though I have never of done this.
The disconnect switch should be used if it is just sitting and NOT connected to shore power.....
OR
If you have an old, cheap single stage converter that keeps the float voltage above 13.4.
Or to put it a different way, except for extended periods of non-use without a charger in use, the switch should be left ON. Some converter/chargers don't like not having a battery there.
38,707 PostsLatest Activity: Feb 28, 2025
