J-Rooster
Sep 09, 2016Explorer
wolfe10 wrote:Brett, I just got back from a trip out to the RV. I own a 2004 Winnebago Adventurer it was Winnebagos top of the line gas coach in 2004. My converter is a Dimensions Unlimited. The unit is mounted under the stove below a drawer very near the batteries. The remote inverter panel is up to the front of the coach above the dash and next to the TV set. There is a small panel that has a off/on switch and a green light which does not come on when I switch the inverter switch to on. There is also a breaker switch above the on/off switch. My inverter is Model is WIN 12/300, Input is: VDC is 12.6, ADC 30, VDC 12.6, ADC 40 and output RMS/VAC 120, Watts 300-400* *= inverter can deliver 400 Watts of constant power for 20 minutes and the 300 Watts in the inverter is continuous. This is all the info that I could muster up! Thanks, John
What make and model inverter/charger do you have?
Do you have a remote monitor panel?
38,707 PostsLatest Activity: Feb 28, 2025
