I just had the house batteries replaced with AGM's. I checked the built in "battery control" and voltage was reading 8.85. This was one week after install. I started the generator to exercise it, the ...
What Type of batteries are recommended? Deep cycle Flooded Lead Acid, AGM , Gel Cell Battery size should not be less than the converter size in AMPS.
Also, you MUST---MUST monitor your new AGM battery/s. DO NOT let them go dead. AGM batteries do not take going completely dead and then recharging. Deep Cycle lead batteries can handle that. AGM's cannot. Doug
