RRTom
Oct 08, 2020Explorer
Battery questions
I just had the house batteries replaced with AGM's. I checked the built in "battery control" and voltage was reading 8.85. This was one week after install. I started the generator to exercise it, the ...
dougrainer wrote:
I hope your Genset and Motorhome are less than 30 days old. If NOT, then the odds are YOU will be paying for the Genset problem. From your description of the Genset problem your GASOLINE has gone bad in the Carb and gummed it up. This is NOT a warranty repair. RVer's need to run their Gensets twice a month for at least 30 minutes and also use STABIL type additive in the Gasoline to prevent Genset Carb problems. Doug
