RRTom
Oct 08, 2020Explorer
Battery questions
I just had the house batteries replaced with AGM's. I checked the built in "battery control" and voltage was reading 8.85. This was one week after install. I started the generator to exercise it, the ...
RRTom wrote:Generally the lights are powered by 12 volts. This can come from the batteries when the switch is on. Or the power can come direct from the PD9270 converter when connected to a power source.
Another question: If the battery is "disconnected" at the switch, should the interior ceiling lights still work?
