While a 8D battery might 'seem' heavy at 120 pounds, these I see are 163 pounds. I hope that you have some strong friends to help install them.
Also it shows that you googled them. Can you pick them up nearby, or do you have to drive a long ways? Most shippers do not handle batteries, as when the tip or leak, they become a huge problem. AGM batteries will not leak, perhaps that is why they can be shipped. However packages over 100 pounds are not shipped by places like UPS, unless they are on a pallet.
If the L6 terminal is your standard car size battery terminal then it should work out well. Yet if it is a 3/8" bolt type terminal, it might be a little small for the starting amperage to go through it. Being designed for primary standby use, it might have either terminal. . .
I happen to like golf cart batteries, with a 220 amp hour capacity in two easy to lift 67 pound packages. I run Trojan T-105 batteries. Trojan is another popular battery supplier. Check your local golf cart company, they might be able to supply your batteries, and by adding your 4 batteries to their order, it can bring them into a special pricing - because of the larger value order. Normally Trojan delivers on their own trucks to many locations.
Good luck!
Fred.
