prism
Sep 29, 2013Explorer
davey123 wrote:
Hi,this is Big Davey 123. First ? is if the light for the coach
side when engaged is not lit does this make a difference? It seems
to work normal anyway. This question is about the battery solinoid
disconnct switch.The light used to work but quit all of a sudden.
Thank you for any insight you may have.
those bulbs are standard automotive and tend to burn out quite regularly.Buy a LED replacement and it will last a lot longer especially if you leave it on for long periods, most are operated through the disconnect switch.
38,708 PostsLatest Activity: Mar 05, 2025
