jwcolby54
Sep 30, 2023Explorer
pianotuna wrote:jwcolby54 wrote:
I found a very good youtube video on lithium vs lead acid. It is by an engineer who did extensive side by side testing in the lab where he could get consistent results for each battery type he tested. It is somewhat long but very thorough.
https://youtu.be/iy3hga_P5YY?si=tr2yG_na_vB5rHmQ
It was done at BattleBorn but the results are the same for other manufacturers.
Thanks for finding and posting this.
Unfortunately they did not cycle the lead acid batteries BEFORE testing.
Lead acid / agm are rated at 25 amps discharge, so testing at 40 amps is not a level playing field.
The low voltage cut out is interesting. I wonder if going to 10.5 UNDER load is the same as discharging capacity to 10.5 volts?
Last winter because of snow cover my house bank went to 8 volts. It has recovered nicely.
I do use my rv at -34 f so Li unfortunately won't be in my future.
Let me start by saying that I am not an EE, however my job for 15 years was fixing electronics, back in the day when a thorough understanding of all things electronics, schematics, o'scopes and soldering irons were the tools of my trade. So I understand this stuff fairly well.
The fact is that lead acid works quite well if you pretty much stay plugged in, or only use the battery for led lights and the water pump etc. Trying to put a high current long draw device on it is where lead acid fails rather spectacularly.
As for 25 amps vs 40 amps level playing field... there is no level playing field. One doesn't get a choice about current draw. Once doesn't get to "cycle before" etc. One turns on a device and one gets what one gets. The Puekert effect is real. Put a 2kw inverter on a lead acid and enjoy the show. Put it on a LiFePO4 and enjoy your hot coffee from your microwave. It really is as simple as that. Even several lead acid batteries in parallel will droop radically under heavy load. I know, I have watched it. Many electric devices do not enjoy trying to run at 11.9 volts which is a very real result of a very high current draw on lead acid.
Every tool has it's uses. Lead acid's use case is low current over long times. Or (for starter batteries) extremely high current over extremely short times. It is decidedly not extremely high current for more than a few seconds. Whatever you do, do not attempt to run an inverter higher than perhaps 500 watts on lead acid, and try to pull full power for long times.
One final thing, LiFePO4 simply doesn't care if you fully discharge it. Lead Acid will die rather quickly if you do that repeatedly.
Every tool has its place.
