FB_Grateful_DadExplorerNov 10, 2014Battery wiring problem. Everything stoppedWhen getting new house batteries installed, it is obvious I mis wired something. When I fired the engine up, it sounded as if the coach system was cycling and checking, then the panel light went off. ...Show More
FB_Grateful_DadExplorerNov 10, 2014I can find no fuses near a positive terminal. And the engine batts are still hot.
Related ContentAG battery switchoverBattery problemBattery ProblemsAtwood water heater problemHouse battery drain
