Old-Biscuit
Nov 10, 2014Explorer III
FB Grateful Dad wrote:
Not on shore power. I have a Xantrax freedom combi inverter charger. Still don't see a fuse.
Combo inverter/charger....OK. Won't be any fuses.but should be Circuit Breakers on inverter.
BUT before doing anything.....
Have you disconnected the HOT engine batteries?
Have you checked the cable connections on the 4 6v house batteries ie: identified which cable is actually negative (goes to frame/grounded)??
Have you check how t properly wire 4 6V batteries as per pictures posted vs how you wired them?
