liborko
Apr 16, 2017Explorer
Batwing directional handle
Does it bother anyone that the arrow on directional handle does not line up with the direction of the antenna? It does me. There is a 90 degree difference between the arrow on the rotational handle and actual direction of the Wingman. To receive best signal the Wingman has to point to the source of signal. Doing it from the inside of the RV without seeing the antenna would be easier if the arrow on the directional handle would point the same way the Wingman does.It does not. Installing Wingman the batwing becomes directional. I fired e-mail to Winegard and their position is the pointer on the handle is for stowing the antenna only. I say why not move the arrow on the handle 90 degrees so it points the same direction as the Wingman and you can use it to point the antenna for peak signal. . To stow the antenna the two arrows need to line up but it is totally irrelevant whether the two arrows point north, south, east or west or anywhere else as long the two arrows line up. It would mean to make new directional handle with the arrow moved 90 degrees. What do you think?
