Executive45's avatar
Executive45
Explorer III
Apr 17, 2017
Bay door locks
All right..I've searched to high heaven for an answer to my problem. Maybe someone on here can offer some advice. I have a Monaco Executive 45PBQ with auto bay door locks. The bay doors can be locked either by pressing the key fob remote or pressing 555 on the combo by the door. Pressing the other button on the remote unlocks them. You can also do so by entering the correct code in the code reader. My issue is this...
Last week the driver's side bay doors decided they wouldn't cooperate with the passenger's side. When I depress the button on the key fob, the passenger side doors open like they should, but the driver's side ignore the command. Using the key pad and I get the same result. I've checked all the pin switches on all of the doors and they appear to be working correctly. I've checked the breakers, the GFCIs and all of the fuses, front run bay, rear run bay and closet. All fuses checked ok.
Anyone have any ideas? The keys open the bay doors and lock them as they should. That said, I'd like to get the remote locks working again if possible. This only affects the driver side of the coach. TIA...
Dennis
