bmwbob
Oct 30, 2016Explorer
Bay door removal
On my '99 Newmar DSDP, I need to completely remove one of the top-hinged exterior bay doors from it's mounting to do some work. The top of the door panel is secured into an aluminum extrusion which o...
bmwbob wrote:
I looked at that information. It appears that this procedure will cause the entire door panel with the extrusion still attached to the top to separate from the hinge bar.
I need to be able to separate the actual door panel from the extrusion for the job I have in mind.
Bob
