jorbill2or
Apr 14, 2018Explorer II
Are the lifelines really 400ah ea .... as in x L 16 ( big) 400 amp hours is more than a GC battery can do ... or are they the same size as the golf carts you had in your prior rig 230 ah ea ? If they are the large L16 then dropping down to the GC2 size is certainly cheaper and possible with only overnight use. You could also drop the agm but I wouldn’t as you would have to check water levels frequently. Probably not something you want to do or read up on.
I also think dropping to 2 L 16’s might be what I’d do .. limited boondocing but ....
38,782 PostsLatest Activity: Aug 23, 2026
