- IvylogExplorer IIIThe pickup screws into the top of the tank...undo hose and unscrew. May have to weld an extension as the diameter is restricted to what you can put over the current one. Check for holes in the one you take out as it should be long enough to use 3/4 of the tank.
- MountainAir05Explorer IIThe tube is build into the fuel pickup which is inside the tank. If you can get to and take out the pickup then you will see how to extend it. Since it is a diesel you can look to see if you can get to the pickup.
38,782 PostsLatest Activity: Sep 10, 2026
