rayleepotter
Jul 18, 2022Explorer
Bed slide
I have a 2015 Winnebago Journey 36M - I have a king sized bed which moves side-to-side. The bed slide only works periodically - How do I access the bed slide mechanism? Can I perform some maintenance...
wa8yxm wrote:
Describe the slide. as follows
With the slide extended are there cables visible? (yes no)
A kind of "Wavy" metal track on the side (yes/no)
Under the slide Toothed rails (yes/No)
Or Hydraulic cylinders (yes/NO)
Pick one of the above or if I've not described it please do.
What is the reason for asking.. Different slides different instructions.
At lest two of the slide out systems I've described use a current sensing controller (same as Kwikee steps do) the theory is when the slide out reaches end of travel the motor stalls and draws more current the controller senses this and shuts off.. Well other things can cause current to increse and trip the OFF switch.
