Biggyniner
Aug 04, 2015Explorer
klutchdust wrote:
On my trip this weekend the bedroom slide was slow to move out, it would stop, then it would go. I have been down this path before but found some loose mounting bolts
that caused it to bind. I did the maintenance on the screw and cleaned the slides. Well it's stuck . I can't find, if there are any, the tools to manually crank it in. The self diagnose
light on the switch doesn't flash, batteries have 13 volts, on ground power this morning. Did the motor go kaput? Once I get it into the full retract position what's next.
Itasca Cambria.
Well if the motor is kaput replacing it should solve your woes.. However it sounds like you may have two problems if it is binding up. Is there any water damage/warpage - Why is it binding?
If you can get the slide in and secure I would take it to a shop and have them look the system over.
38,769 PostsLatest Activity: Mar 31, 2026
