Hi all. I usually am in the TH section but a buddy is having a problem so thought I'd asks the experts here. He just bought a 2007 Fleetwood Revolution and we can get the front and outside TVs to work...
Well. Lots of possibilities here. I had a similar issue and it turned out that I had to go into the "setup" menu on the bedroom TV itself. This was some time ago, so I don't recall the exact settings that I ended up changing, but if you're used to setting up televisions with various input devices you might discover that it's a simple fix.
